JordoLights
Hi Guys, already planning out this coming year's display. It's only 321 days before the 1st of December . Hoping to get some of your input.
Planning to upgrade my setup and use Alan's @AAH HE123 as my main controller this year. Also using some Power8's to distribute power around. Power source would be 2x LRS-350-5 PSU's. I will have roughly around 3,300 5v pixels @ 30% brightness.
Below is a simple diagram that I quickly did for this post. So my questions are:
1. If I use 10AWG wire for all the V+ and V- connections below, would that suffice? Is tinned copper wire core material okay to use?
2. Can I use only 1x mains cable to power up both power supplies?
3. I read that the V- is already linked in all the ports of the HE123 and Power8's. Do I still need to link up the V- for both power supplies? If so, is it just a matter of connecting a 10awg wire from one of the V- ports of PSU #1 to PSU #2?
4. What kind of terminal block would you recommend?
Edit: Power8 #1 and #2 will only power inject to props connected to HE123 Ports 1-8. Likewise, Power8 #3 & #4 will only power inject to props connected to HE123 Ports 9-16.
I'm all ears for any suggestions or even better layout than what I'm planning. Thanks in advance.
