ChristmasInKaralee
110-240V AC WIFI S20 Timer Windows Application. Control Lights, power injection, controllers and more. Free to use.
The S20 WIFI timer lets you schedule when to turn On and Off anything that's plugged into it, see photos and links below. They come in US/EU/UK/AUS plugs.
I have purchased a number of the Orvibo S20 WIFI timers ($20 to $25 US) and they can be purchased from Amazon, Ebay, AliExpress and many other online stores. As there was no Windows application to control these devices and add schedules I thought I would create one and allow anyone to use it to control their S20's.
The S20 can be controlled by the WIWO Mobile app (Android/IOS) however this has it limitations which is why I created my own.
The features of my app include:
- Register an Unlimited number of S20 devices to be controlled (well, limited to the number of DHCP addresses you have available on your network, so ensure DHCP is switch on and you have some available).
- Fully automatic, making it very simple and user friendly.
- At the push of a single button the app will find and register the device on your network. No need to know IPAddresses or MacAddresses of the devices, all you will be asked to do is enter your network password and to name the Device if found (for example "Main Controller").
- Create an unlimited number of schedules for each device. Set time, days and trigger On/Off.
- Natively control your S20's from within a Vixen 3 Sequence. See instructions in S20 App or video below.
- Not sure about other sequencers, however if the sequencer is capable of adding a Command Line effect to the sequence then it will be able to control your S20's.
- Create Groups so Vixen 3 can turn on/off all devices in that group.
- You will need to have this app running for the devices to be automatically controlled, either by Schedule or by your Sequencer. (Note: You could add another command line in your sequence to start this app first.)
- If the S20 is issued a new IP from DHCP there is no need to re-register as my app will automatically update IPAddresses when required.
- Any changes are automatically saved.
- Using remote desktop, the S20 can be controlled to allow any changes while your away from home.
VIXEN 3 Control - This is the big one for me as it allows me to create a start-up Vixen 3 sequence that will turn on all my S20's, therefore tuning on all my Controllers, Power Injection power supplies and any lights that plug into the wall. You can set the sequencer to run this sequence any time before your show starts to ensure all your power needs are turned on, this will in turn save power as you can turn them on just minutes before your show starts and again add another sequence to turn them all off when the show finishes. Even during your show you can turn On and Off power to static lights etc.
NOTE:
- I have not created an install file for this app as it only has three files so just Unzip the files to a folder and run from there. You may need to add the "C:\users\COMPUTERNAME\appdata\roaming\S20 WIFI Control" to your Virus software exception list as this is where the software settings are stored.
- For your information, once the app is running and you have registered your devices and created schedules the app will create a "S20WIFIControl" folder in your Documents area.
S20 WIFI Control Software link Version 1.1 32bit and 64bit - Copy all the files in the link to a folder on your computer.
https://www.dropbox.com/sh/99ew428bd6y2rn8/AADJ9AxFbvULry_ZpZBt-yUia?dl=0
Please enjoy and feel free to provide feedback or feature requests (not that I can think of anymore).
Videos:
S20 Introduction Video
https://www.dropbox.com/s/o67ghmro82wiqll/S20%20Introduction%20Video.avi?dl=0
S20 Controlled via a Vixen 3 Sequence
https://www.dropbox.com/s/ad4q4r6s2zko1zm/S20%20With%20Vixen%203.avi?dl=0
Purchase from one of these below or just do a goggle search for S20 WIFI.
Amazon - www.amazon.com/Orvibo-Electronics-Anywhere-Control-Function/dp/B00KT50HK4/ref=pd_cp_60_2?ie=UTF8&refRID=0YY11MZYEHW1Y70SHAZP
Aliexpress - http://www.aliexpress.com/wholesale?catId=0&initiative_id=SB_20150622203919&SearchText=s20+wifi
Ebay - Just search S20 WIFI
Geoff
NOTE:
Videos:
Geoff
