12v or 5v - Current draws compared
AussiePhil
Administrator
Canberra, ACT, Australia
This is not quite a like for like but it is head for head and a comparison of two 100cnt strings
Parameters
For the record we capture the LED current and the Pixel current as two separate numbers
All current numbers unless stated are for 100% white.
12v Pixels
  • Unregulated, resistive bullet pixels
  • 20CWG wiring
  • 2811 protocol
  • these were a simple purchase of pixels from a pixel supplier from China
  • testing revealed these are 27mA per LED
  • 29.8mA per pixel
5v Pixels
  • 2811 based square nodes
  • 18CWG wiring
  • These came from Ray Wu in Nov
  • testing had 47mA per LED
  • 47.8mA per pixel
Both strings feed from each end with 1M pi leads to minimise any voltage drops for PI leads
So first measurement was to check current when just powered up and when blacked out.
This is known as the quiescent current.... and gives the power used when the lights are powered up and doing nothing
5V12V
Quiescent70mA200mA
Black out80mA280mA
So lets draw that out to a 2000 pixel megatree with 20 x 100cnt strings
At 5v
0.08 x 20 = 1.6A x5v = 8W
at 12v
.28 x 20 = 5.6A = 67W
So what Current do we see for 100 pixels at 100%
5v12v
Amps - 100 cnt draw - 100%4.242.87
Power in watts21.234.44
So we see less current on the wires which helps with voltage drop meaning we do have longer runs between injection points
BUT
we also see 63% greater power consumption for the same number of pixels
Lets again use the 2000 pixel megatree with 20 x 100 cnt strings
12v
20 x 34w = 680w.
5v
20 x 21w = 420w
Now a couple of observations
  • The 12v resistive pixels got warmer but not where you may suspect, see the thermal image below but it appears to be the LED itself
  • Using a light meter the 5v pixels were brighter at the same % level
  • Reducing the light reading on the 5v pixel to match the the 12v pixel seen the 100cnt current drop to 3.2 Amps and the drive % to 73%
  • This would see the power required for the tree drop to 306w
  • This actually fits with an old statement that 12v pixels need twice the power
Video of the ramp from 0 to 100%
View: https://vimeo.com/670152673
Open to questions and further test requests
Phil
ezellner
West Bloomfield, Michigan, USA
To me, this is important especially for those just trying to decide what type of pixels to purchase. My home is almost 90 years old. Exterior power outlets were not a thing back then. It is extremely difficult to run a new line from the breaker box due to slab and crawl space construction. I installed one 120 V 20 Amp circuit to power my entire show. The show was designed around this limit which demanded use of 5 V pixels to get all the props I planned. The amount of extra effort for power injection was trivial in the overall scope of things. Thanks for the all the time you put into the comparison, Phil.
TerryK
Retired Elf
West Central Ohio
... Now a couple of observations
First, what type of light meter? Are you taking an actual measurement or just making a relative comparison?
"light meter the 5v pixels were brighter at the same % level" Expected in my thinking as you were using 12 Volt Resistor pixels. The internal pixel arrangement of components and their values change the 'rules' a bit.
"This actually fits with an old statement that 12v pixels need twice the power" Politely, I do see this statement as being very accurate in my opinion. Rather power being a calculated value would depend upon the voltage drop from the source to the level required/needed by the internal components of the pixel and current draw at the component voltage. So, a ratio of 5 to 12, approximately 2.4 times as much. Baring in mind that voltage drops along the length of a string, it is also somewhat a 'moving target'.
AussiePhil
Administrator
It was an actual electronic Lux meter, not calibrated so the values are good for relative comparison and general illumination values. I tried to control the readings and conduct them in a consistent manner. For the record I cut a short length of 40mm pvc that i used to block out external light, the pixels were positioned directly up with the Leds at the same distance from the reading head, the head neatly covers the top of the pipe completing the sealed setup.
It's not perfect but is far better than just a visual look by eye.
lets say the 12 measured 270 lux and the 5v was 330, i then would down the 5v brightness/intesity in vixen to 73% to get the same 270 reading.
both styles use 2811 led controller but the 12v pixels have components that are limiting the max white current level to 27mA, the 5v ones were 42mA
the 2811 data sheet shows 18.5mA at 5v, this seems to fall off as Vdd drops over a string ... future test to confirm.
All of this is variables and actually can be estimated based on the loop resistance and the input currents to the circuit.
As above the moving target can be calculated, the practical comes in around 2x with a bunch of variables in play it would seem.
Phil
MichaelF5
West Hoxton
that reminds me... It'd be interesting to see you push the limits of the Volt regs... even just on a single pixel, from vague recollection they were rated for max volt 25 or 30?
AussiePhil
Administrator
Brilliant thankyou!
do you have more pixels to test the limits of injection points?
I don't have more 12v pixels at this time and unlikely to buy more 2811 12v ones. The limits though can be fairly accurately estimated based on the minimum operating voltage both to display white and to also get consistent intensity levels.
I did do an improptu test to confirm minimum operating voltage using the electronic load to simulate additional pixels.
The pixels stopped being white around 3v which is around the nominal Vf for a blue LED. As the Vf for blue can be as high as 3.4v a safe Min voltage would be 3.5v.
What I observed fits with the guideline "no more than 100 pixels to power" for 12v. for 18cwg this may well stretch to 150 pixels and of course if you limiting the intensity levels then it will be higher.
AussiePhil
Administrator
Update Info:
Counted the strands and measured the strand size
Took multiple readings with the digital calipers and got around 0.14mm diameter
There were 21 strands in the bundle,
This gives a calculated real AWG of 22, the measured resistance equates to a 24AWG wire
When i count i bundle to 10 strands each so 21 strands in the image
I've spotted a couple vendors now start to quote strands and strand size in listings
TerryK
Retired Elf
West Central Ohio
What is the wire type in the graphic? Obviously not bare copper. Tinned copper? Aluminum?
If vendors are beginning to list strands and strand size then wire type is just as important.
AussiePhil
Administrator
I can't tell by looking at it but there is no copper colour in the cut ends and it measured resistance is close to the published numbers for aluminium wire of that sizing, so expect it to be aluminium.
The vendor I bought some M16 pigtails from was listing type (copper) and mmsq at least, another also listed the strands.
We should be asking this info from the vendors as I agree it's important.
scamper
collie
these tests just prove the theory. As all led's are the same voltage essentially, it is natural that a 12v string is going to use more power as you need to dump the excess voltage which cannot be done without some kind of power draw /loss
