- Thread starter
- #16
Confirmed - it was you that made me go back and try this... thanks
Phil
Bird said:Slite said:Not willing to settle for clear. Trying to find a way to make the tubes opaque to better defuse the light.
Have you tried wiping the clear conduit with something like Acetone, as it has the ability to disolve most plastics.
Steve
Timon said:In general I love what you've done. I think the only change I'd make would be to use pixel strip instead of RGB strip.
If that's electrical conduit it likely has UV inhibitors since PVC electrical conduit is made for outdoor use.
Again great job.
John
dariansdad said:http://www.shannonclaus.com/CCR%20Spiral/CCRSpiral.html
Check out this using PEX tubing. Awesome affect and the CCR from LOR used is not inside the tubing, although through communication, it was suggested to them to use a larger piece of tubing and run the CCR pixels inside. This may be a different way to accomplidh what you're looking to do
