Release 2017.33 xLights released
smeighan
4217 Greenfinch Dr CO 80126
2017.33 released
This is marked as the next Beta release. Be aware that the developers feel the latest Beta is always the best version to use. Each Beta fixes bugs from previous released. With that being said, 2017.32 is a stable release that can be used for your shows this season.
Thanks again to our developers!
2017.33 Oct 15, 2017
-- bug (gil) Fix Galaxy not blending when reverse is checked. Fixes #949.
-- enh (keith) Add xSchedule gamma processing on output
-- enh (keith) Add FPP master support for pixel sticks and Falcons
-- bug (keith) Fix xSchedule play last item only once plays repeatedly
-- bug (keith) Fix scrolling sideways using Shift+scroll wheel stops paste using right click menu working
-- bug (keith) xSchedule FSEQ, Video and audio dont respect the delay setting
-- bug (keith) Fix upload to falcon hang if multistring element goes past configured string ports
-- enh (keith) Add check sequence check for non contiguous models on the same controller connection
-- enh (keith) Add xSchedule can act as a remote using the csv sync packets (which are routable)
-- enh (keith) Add cropping to the video effect
Grandpa Elf
Excellent work guys. I was going to mention the "xSchedule play last item only once plays repeatedly" tonight but you beat me to it!
