Release 2019.26 Released
keithsw1111
Kellyville, NSW
2019.26 May 24, 2019
— enh (scott) When prompting for missing audio include the original audio filename to make it easier to find
— enh (scott) When audio is missing look down 1 folder and grab it from there if found
— enh (keith) Add plugin functionality to xSchedule. See “Plugin Docuentation.txt” in github for the interface specification. Also in github is a C# plugin wrapper with simple UI.
— enh (keith) Move SMS Daemon to be an xSchedule plugin
— enh (keith) Suport a “-shimmer” suffix on phonemes which will shimmer the phoneme mouth. This needs to be manually added where you want it
— enh (keith) When dropping a video file and creating a video effect get smarter about the length of the effect created
— enh (keith) Add a right click menu to the test dialog channel lists to quick select/deselect channels/models/outputs
— enh (keith) When editing jukebox button definitions always pop up the dialog near the button
— enh (keith) Fix #1554 add a set mode api to xschedule to turn on/off master and remote modes
— bug (keith) Fix #1553 xschedule test mode disable does not restore xSchedule prior mode correctly
— enh (keith) Fix #987 Add preset length to effect preset panel
— bug (keith) Fix #959 Edit effect timing does not allow keyboard entry
— enh (keith) Add a CTRL-A keyboard shortcut to layout panel to select all models
— bug (keith) Remove a memory check in win32 which older versions of windows dont support
— bug (dkulp) Better handling if other FPP discovery nodes are found that aren’t FPP (like ESPixelSticks)
— bug (dkulp) Try to detect if “null” hostnames would appear in FPP Connect and ignore
— enh (lee) Save audio volume between xLights runs
  • Like
Reactions: AAH
