Release 2019.28 Released
keithsw1111
Kellyville, NSW
2019.28 June 8, 2019
— enh (scott) Add filename tooltip to colour curve buttons
— enh (kevin/keith) Add shader effect
— enh (keith) When importing a timing track from xLights sequence and the name clashes overwrite if there are no existing timing marks
— enh (keith) Allow xSchedule to access more than one MIDI device at once
— enh (keith) Add “Set step position” and “Set step position ms” xSchedule APIs
— enh (keith) Add ability to clone xSchedule playlists, steps, items and schedules
— enh (keith) Add the ability to set the Force Local IP in xSchedule
— enh (keith) Add the delay setting to the text playlist item
— enh (keith) Add check sequence check for matrices where strands/string does not divide evenly into string length
— bug (keith) Fix autosave volume does not restore correctly
— bug (keith) Fix xSchedule web page handling when plugins not running
— bug (keith) Fix default web page not working
— bug (keith) Some fixes to event playlists
— bug (dklup) Fix handling of multiple FPP with same hostname
