keithsw1111
2019.32 June 30, 2019
— enh (keith) Add MQTT support to xSchedule … both publish and subscribe
— enh (keith) Add support for static and dynamic PS to xSchedule RDS
— enh (keith) Add waveform band pass filters for partial frequency waveform visualisation in sequence waveform display
— enh (keith) Warn users opening xbkp files that they will save as xml
— enh (keith) Add more blend styles to sup import … also change the default as the old one did not handle overlapping images correctly
— enh (scott) Add uniqueness ip & description check to e131 where auto size is enabled
— enh (dkulp) Start introducing FPP proxy configuration of controllers accessed via FPP
— bug (dkulp) Fix backup on start on OSX fails
— bug (keith) Fix arduino buttons code for driving xSchedule sending messages delayed by one button press
