Release 2019.39 Released
keithsw1111
Kellyville, NSW
2019.39 August 9, 2019
— enh (dkulp) Discovery – match IP addresses to resolved hostnames as well
— enh (dkulp) Add ability to convert ZCPP output to e1.31
— enh (keith) Let user adjust maximum blank frames when generating custom model
— enh (keith) Have the UI stop the user from setting up previews other than default in 3D as they cant actually be viewed in 3D in playback
— enh (keith) Make SMS service test work even when no service has been signed up for
— enh (keith) Add a F12 force keyboard focus in sequencer to allow keyboard recovery from entry fields stealing focus
— enh (pete) Add logarithmic x Axis to music effect
— bug (dklup) Fix FPP connect upload of sequences that take longer than 10 seconds to transmit
— bug (keith) Fix cant delete polyline point in 3D
— bug (keith) Fix Metronome timing tracks not working
— bug (keith) Fix changing sequence timing does not immediately change fseq file timing
— bug (keith) Fix making 2 and 3 point models the same size does not work
— bug (kevin) Fix broken transitions
