Release 2019.54 Released
keithsw1111
Kellyville, NSW
2019.54 September 27 2019
— enh (keith) Add support for video files with an alpha channel to video effect
— bug (keith) Fix double click output changing IP address (where last output with that ip address) does not update models that refer to the ip address
— bug (keith) Fix 3D preview of custom model data does not render correctly if no sequence is open
— bug (keith) Make vu meter timing track effects work with multi-layer timing tracks (but it will only use the top layer)
— bug (keith) Fix issues with single channel matrices not behaving correctly
— bug (keith) Fix model group warning on startup when there is a blank model name in the list
— bug (dkulp) Fix FPP upload of reverse setting on virtual strings
