Release 2019.61 Released
keithsw1111
Kellyville, NSW
2019.61 October 26 2019
— enh (gil) Add Redo option for the sequencer grid. Fixes #555.
— enh (dkulp) FPP/BBB DMX strings – set minimum length to 16 channels. Several controllers have issues with less than that
— enh (dkulp) FPP Connect – use a single progress dialog to avoid stealing focus for each thing transferred
— enh (keith) Add special.options file for technical options
— enh (keith) Add xSchedule API for querying pixels which have been set via the API
— rem (keith) Remove Syncrolight support due to legal threats
— bug (dkulp) FPP Connect – only remembered manually added FPP instance hostnames if they exactly matched (case sensitive)
— bug (kevin) Fix certain shaders from ISF failing to compile
— bug (keith) Fix loredit import crashes on strand mapping import
— bug (keith) Fix loredit does not import all nodes on a strand
— bug (keith) Fix reversed model should always be on a new virtual string
— bug (keith) Put a bunch of extra defense in xFade against corrupt packets
— bug (keith) Fix render cache purged when sequence closed
— bug (keith) Fix some old rotozoom value curve errors
— bug (keith) Bunch of windows hardware video decoding fixes
— bug (keith) Fix submodels dont highlight when clicking on them in model list
— bug (keith) Dont auto chain DMX models
— bug (keith) Fix auto serial start channels not correct when models overlap
— bug (keith) Fix boxed models generate illegal scale if x or y dimension is 1
— bug (keith) Weird effects grid behaviour if effect starts and ends < 0ms
