Release 2020.17 Released
keithsw1111
Kellyville, NSW
2020.17 May 1 2020
— enh (keith) Add native media player option for video in xSchedule. This slightly reduces control but improves performance
— enh (keith) When using DMX effect on model group label the sliders using the node names from the first model in the group
— enh (keith) Increase beam length of DMX moving heads and add visual control over beam width
— enh (keith) Reorganise the tools menu to group related items
— enh (keith) Add support for strings of single colour but individually controlled nodes
— enh (keith) Make picture effect display red when picture is missing much like video and shader effects do
— enh (keith) Scrub model preview along with the audio
— bug (keith) Try to force dialogs that dont appear on any monitor onto a monitor
— bug (keith) Fix picture effect tiling issues where tiling is not complete.
— bug (keith) Fix effects on model group with horizontal or vertical scaled render styles but containing no models crashes when rendering
— bug (keith) Fix some erroneous check sequence errors re subbuffers on per model render styles
— bug (keith) Fix crash in visualiser when controller with no protocols is assigned to a port
— bug (keith) Fix area flood beam length is anchored to z=0 rather than moving with the flood
— bug (keith) Fix models with uneven strings dont show correctly in visualiser
— bug (keith) Fix issue with unused smart remote port causing weird config on a falcon
— bug (keith) Fix issue with loading downloaded DMX fixtures
— bug (keith) Fix unable to map multiple channels from a single prop in the LMS import
— bug (scott) Fixed AlphaPix Upload for Firmware 2.16+
— bug (scott) Fix force ip not working on controller tab
