Release 2020.32 Released
keithsw1111
Kellyville, NSW
2020.32 August 21 2020
— enh (scott) Give an option to add imported models to existing groups or continue to create new groups when importing models containing submodel groups
— enh (scott) Lower arch minimum hollowness to zero
— enh (keith) Add minleon controller upload support
— enh (dklup) Add new Kulp controllers
— enh (dkulp) Auto select first controller variant when available
— bug (scott) Fixed Select Effects Window not finding effects on submodels/stands
— bug (scott) Fix windows download link does not work
— bug (scott) Fix spakles with a value curve at zero still displays sparkles
— bug (scott) Model search should not be case sensitive
— bug (scott) Fix video export required stereo audio
— bug (scott) Fix select effects does not select effects on strands and nodes
— bug (priemd) Fix xmodel export includes empty groups
— bug (priemd) Fix 3D object model move rotate etc not working
— bug (keith) Fix issue clicking and dragging out line model in 3D
— bug (keith) Fix sunset and sunrise not saving in schedules
— bug (keith) Fix a bunch of issues with transition window controls doing weird things. They now enable and disable more consistently
— bug (keith) Auto handle really screwed up polyline models restoring them back to editable state
— bug (keith) Fix old AC LMS import does not import twinkles as twinkles
— bug (keith) Fix and rework the way visualiser drag and drop of serial output models work
— bug (dkulp) Fix serial port config upload to FPP controllers
  • Like
Reactions: AAH
Downloaded it on Zoom 10 min ago!
I presume now it's been fully released the download link from xLights won't lead to a 404 on the website.
