Release 2020.50 Released
keithsw1111
Kellyville, NSW
2020.50 November 29 2020
— enh (scott) Added Export Controller Connections to Tool Menu. This exports a CSV file with all
the ethernet type controllers and the models attached to each port.
— enh (scott) Added “Scale Keep Aspect Ratio Crop” to the Picture Effect.
— enh (scott) Added “Ctrl/Cmd + Scroll Wheel” Page Scrolling to Custom Model Dialog .
— enh (keith) Add bulk move and bulk remove to visualiser right click menus
— enh (keith) Add node find right click menu options to custom model dialog and submodel node selection dialog
— enh (keith) Add option to set remote falcon into enable mode when not playing supported playlists
— bug (scott) Fix Check Sequence Connection Error for Auto Configure Panel Controllers.
— bug (keith) When a controller is in auto layout mode then recalc before saving controller tab and when opening visualiser
— bug (keith) When switching between virtual strings falcon upload should reset overridden properties to the default
— bug (keith) Fix circle model inside start location generates incorrect buffer/wiring
— bug (keith) Fix incorrect controller rebooting message when uploading to old firmware on F48 controllers
— bug (keith) When using auto layout remove individual start channels from models as these cause issues
— bug (keith) Fix single channel window frames display as a single dot
  • Like
Reactions: AAH
Hi Keith, it seems a couple of the later versions of xlights have a issue with the "RGBeffects" file in ubuntu linux,
I restore from a working rgb effect file an xlights load fine.. make any changes an save them.. next time i loads xlights it says it cant find the file.
is that a simple fix i can do this end?
Version that works fine with no issues was 2020.31
I noticed the issue in .47 and .50 as well
I also have ver .35 and .42 to check, to see if i can pinpoint what version this issue started happening.
Send me the file after saving. If i can see why it fails to load I may be able to work out why this is happening.
