Release 2021.06 Released
keithsw1111
Kellyville, NSW
2021.06 March 1 2021
— enh (kevin) Add Circles and Shatter transitions
— bug (scott) Prevent groups with blank name
— enh (scott) Add multi selection to submodel import in Faces dialog
— bug (scott) Fix AC toolbar
— bug (scott) Fix sequence import with spaces at the beginning of folder names
— enh (scott) Add BBB16 controller configuration
— bug (dkulp) Fix Shader effect panel sliders/controls not triggering render
— enh (dkulp) Add KiNet uploads to FPP output universes
— bug (kevin) Fix pinwheel and star transitions being inactive for some of the duration
— enh (kevin) Allow reverse on star transition
— enh (kevin) Add swap, shatter, and circles transitions
— bug (dkulp) Fix issues with effects that need to render on the main thread being rendered WAY too often if “Per Model” used.
