Release 2021.38 - 2021.40 Released
keithsw1111
Kellyville, NSW
2021.38 November 20, 2021 (manually imported from README.txt)
— enh (keith) Add auto layout for J1Sys
— enh (keith) Add segment measures to Polyline
— enh (keith) Make state on faces and state effect bulk editable
— enh (dkulp) Use multi-cores for Lines effect to speed up rendering
— enh (dkulp) Add "Blur" to Experimental GPU/Metal Rendering Engine
— enh (dkulp) Bunch more optimizations to Butterfly for Experimental GPU/Metal Rendering Engine
— bug (dkulp) Fix v2 smart receivers not being selectable for FPP capes based on ttyS serial outputs
— bug (dkulp) Fix rare crash-inducing race condition in the JobPool
— bug (dkulp) M1Pro/Max fails to decode some mp4 files, detect and fallback to software decoding
— bug (dkulp) Fix vertical grid lines on non-Retina displays
— bug (dkulp) Revert back to OpenGL on OSX until all views can be converted to Metal to reduce vsync contention
— bug (scott) Fix some issues if a controller that a model is assigned to is no longer available preventing it from being assigned to a new controller
— bug (scott) Fix issues with new curl lib and some controllers on latest Linux/OSX
— bug (scott) Fix HinksPix port display for multistring models
— bug (keith) Fix auto layout models does not correctly handle model after one with start nulls if it has none.
— bug (keith) Invert layout when printing
— bug (keith) FV3 splits not calculated correctly if dummy pixels required.
— bug (keith) Display controller connection properties consistently.
— bug (keith) Have save buttons when linked show red if either layout or controllers need saving
2021.39 December 5, 2021 (manually imported from README.txt)
— enh (keith/dkulp) New REST/Scripting API for controlling xLights from scripts (work in progress)
— enh (scott) Basic script/automation runner dialog
— enh (keith) FPP Connect to remember column sort order
— enh (Camden Narzt) Add alternate nodes ability to vertical matrix model/tree
— enh (keith) Include sequence name when reporting excessive mmissing models
— enh (dkulp) Add "V2 ZSTD/Sparse" to default save type in Preferences panel. Can be used to create sparse sequences that only contain multiple specific model to act as effect sequences for FPP.
— enh (keith) Update to latest libcurl on Windows to fix some FPP Connect crashes
— enh (keith) Fix maximum generic serial payload size to 4096 bytes
— bug (keith) FV3 copies group count from first virtual string when it shouldnt
— bug (dkulp) Uploads to Beagles may not adjust to proper compression level
— bug (keith) Fix Fv4 sequence upload at level 9 causes playback issues, reduce compression level
— bug (keith) Fix some issues with LOR Optimised output would not send anything for long periods of time
— bug (scott) Fix HinksPix SR AC Upload
— bug (keith) Fix #id:sc not working for serial controllers
— bug (keith) Fix Falcon upload of Start Nulls
— bug (keith) After reconfiguring, give Fv4 controllers longer to reboot
— bug (dkulp) Fix various effects that are rendering improperly on multi-layer stars
— bug (dkulp) Fix layered arches to "Inside" layer is actually the inside layer
— bug (dkulp) OSX/Linux Preferences "Other" tab settings getting wiped out when opening preferences again
— bug (dkulp) Fix a semi-common crash in AudioManager when closing sequences
— bug (dkulp) OSX - if opening the hardware video encoder for exporting preview video fails, try dropping tompeg4 instead of h264/5
2021.40 December 20, 2021
— enh (scott) Add alternate node support to horizontal matrix
— enh (keith) Add a selected count on FPP connect
— enh (keith) Detect when user tries to use AC mode without a suitable timing track
— enh (keith) Add ability to stretch custom model data to grid size
— enh (keith) Add Ctrl A-x + space to fast set smart remote of selected model in visualiser
— enh (keith) Add support for double height of waveform (without increasing display height)
— bug (scott) Fix hinks export on OSX
— bug (keith) Fix polyphonic transcription does not display notes
— bug (keith) Fix race condition sometimes experiences uploading to F48V4
— bug (keith) Fix ripple effect xcentre affects the ripple amount
— bug (keith) Fix a pixlite serial port upload error where there is a gap in used channels
— bug (keith) Fix xSchedule refire frequency fires immediately if started late
— bug (keith) Fix tooltip lingers after you start to drag model in visualiser
— bug (keith) Dont defaul matrix faces
— bug (keith) Fix xSchedule Remote Falcon API calls failing
— bug (keith) Fix sequences and lyric tracks download with wrong file extension on OSX
— bug (keith) Fix device naming is inconsistent between xScanner scans
— bug (keith) Fix an old value curve on Single strand reports upgrade issue
— bug (dkulp) Fix doublie clicking on xsq directory access issues
— bug (dkulp) Fix canvas layer changes not always detected
