Release 2022.11 Released
keithsw1111
Kellyville, NSW
2022.11 May 21, 2022
— enh (scott) Added Load from State to DMX Effect
— enh (scott) Add import from SVG to Sketch Assistant Panel
— bug (dkulp) Fix toolbars/images on Windows with non-100% scaling (WIP)
— bug (dkulp) Fix drag/drop in Import Dialog on MacOS
— bug (dkulp) Fix video stream of exported House Videos if codec has to change from defaults
— bug (dkulp) Maybe fix green video export on MacOS
— bug (dkulp) Change how buttons with background colors set are drawn on MacOS
— bug (dkulp) Fix hang with drag/drop of Faces Effect
— bug (dkulp) Fix a crash situation if a buffer is reported as being larger than it actually is
— bug (keith) Fix a possible OpenGL crash if context cannot be created
Hi Keith,
Just wondering if its possible to add like a pixel width ,
eg a arch @ 8 pixels wide, or candy cane @ 6 pixels wide or any of the other props?
Currently xlights is 1 pixel wide (unless you make a custom prop)
Is it possible?
Is it possible?
Arch supports "Layered Arch".
Similarly, stars and circles support layers. Candy cane I think doesn't, but for precision custom models make a bit more sense on the candy cane.
Thanks for that info, never saw the layers before.
for a 3.3m candy cane with a width of 8pixels and 400 odd pixels for the straight bit an 500 odd for the arch bit.
a custom model would be a Pain
looks like i might have to make 2 different modules. an name it 1 element.
thanks for your help
