Release 2022.12 Released
keithsw1111
Kellyville, NSW
022.12 June 7, 2022
— enh (scott) Move ScottNation controllers under their own vendor
— enh (keith) Rewrite custom model generation to use a faster algorithm
— enh (scott) Add DMX colour wheel support
— enh (keith) Lift Falcon V4 max group size to match latest firmware
— enh (dkulp) Add twinkly output upload to FPP
— enh (dkulp) Merge artnet multi-lines to one when uploading to FPP
— enh (scott) Added the Ability to define “Preset” channel values when render non DMX Effects on a DMX model
— enh (keith) When a ruler is defined on import or export of some model types save the real world dimensions
in the xmodel file and apply them when loading it
— enh (keith) Add an option to silence the audio in xLights
— bug (scott) Fix faces effect required a minimum of 10 states
— bug (scott) Fix default gamma not saving
— bug (keith) Fix twinkly model data import imports upside down
— bug (dkulp) Abort render whenever a model group is changed
— bug (keith) Abort render whenever a timing track is deleted or renamed
— bug (keith) If there is no LUA mime handler use the txt handler instead
