Release 2023.10 Released
keithsw1111
Kellyville, NSW
2023.10 June 30, 2023
— enh (dkulp) Add node number under mouse cursor to lower right corner of SubModelDialog
— enh (scott) Add zero layer size for circle model (for center pixel)
— enh (keith) Enable ESC to close visualizer
— enh (merryoncherry) “Batch Render” enhancements to disable various warnings, modal dialogs, etc…
— enh (keith) Allow ovverride of Twinkly http port
— enh (MartinMueller) Add full set of ESPv4 variants
— enh (scott) Add HinksPix Pro 80 support
— enh (dkulp) Enable HTTP/2 for FPP Connect and Discovery
— bug (merryoncherry) Fix issues with bulk edit of effects
— bug (dkulp) Fix crashes when selecting Vendor/Model/Variant using keyboard
— bug (dkulp) Fix FPP Connect if there is a powered on Falcon v4 controller on the network
— bug (dkulp) Fix square pixel type on Windows
— bug (scott) Serial port configuration fixes
— bug (dkulp) Fix animated GIFs not working properly
