Release 2023.14 Released
keithsw1111
Kellyville, NSW
2023.14 Sep 16, 2023
— enh (keith) Twinkly reconnect after power cycle
— enh (scott) Add more WLED pixel types
— enh (scott) Update SanDevices upload to work with 5.5/5.1 firmware
— enh (keith) Preliminary Falcon V5 support
— enh (scott) FPP controllers default to DMX-Open instead of DMX-Pro
— enh (scott) Add Full xLights Control for HinksPix
— enh (dkulp) FPP Connect – show discovered but unsupported FPP instances
— enh (lasershane) Implement model layout options for Distribute Depth and Alight Depth Center
— enh (dartunder) Update group center mark to use handle size selection
— enh (MrPierreB) Two new layer blending styles
— bug (dkulp) Fix parsing of JSON with unicode characters
— bug (scott) ESPixelStick should not allow “KeepChannelNumbers” setting
— bug (scott) Allow more than 12 universes for ESPixelStick on controllers that support it
— bug (scott) AlphaPix/ESPixelStick/SanDevices/WLED – make sure valid controller settings are used for various things
— bug (keith) Disable Twinkly outputs still try to connect
— bug (dartunder) Fix hyperlink for FPP instances behind proxy in FPP Connect
— bug (gjones) Fix bug where inactive models could be selected in 2D
— bug (gjones) Fix import bug for models with Per Model render buffers when a single model of same name exists.
KiwiPhil
North Brisbane
Hey @keithsw1111 where can i ask a developer questions about xLights code base?
Hoodlum
haha yeah... im there already contributing to the repo, i thought there might be a developer forum so the issue requests don't get clogged up with my stupid questions, and i can't seem to find a code / contributor wiki other than the contributor.md in the repo.
TY @KiwiPhil
