Release 2023.19 Released
keithsw1111
Kellyville, NSW
2023.19 Nov 4, 2023
— enh (keith) Add webp image support
— enh (dartunder) Add warning and make it easier to see that a model had a shadow model in visualizer
— bug (Daniel Hacquebord) Fix dark mode for shadow models in visualizer
— bug (scott) Fix AlphaPix upload
— bug (keith) Fix crash with liquid effect on large models
— bug (scott) LUA Script: Select Sequences and deselect highlighted does nothing
— bug (dkulp) FPP Connect: not uploading serial outputs from FPP Connect (worked fine from controller page)
— bug (dkulp) FPP Connect: not able to upload to FPP instances with UI password set
— bug (dkulp) Fix crash on MacOS with RotoZoom if GPU is busy
— bug (dkulp) Workaround some other common crashes, but underlying cause of crash still under investigation
