Release 2024.15 Released
Status
Not open for further replies.
keithsw1111
Kellyville, NSW
2024.15 August 22, 2024
– enh (kylegrymonprez) Add ability to set the alias behavior for renaming models
– enh (kylegrymonprez) Add FPP Connect button to setup tab
– enh (scott) Allow overriding named color pallets
– enh (scott) Add face definition name to check sequence for missing pictures
– enh (scott) Add Set Palette Name
– enh (scott) Galaxy Effect – add scale to buffer
– enh (derwin12) Warp Effect – Add Flip option
– enh (sidelights) Single Strand Effect – add additional fade types
– enh (cybercop23) Allow animations for the Model Viewer
– enh (PeteMathews) Add support for BaldrickDMX board
– enh (jasonsomers) Add support for new variant of RGB2Go-Duo2Go
– enh (dkulp) Skull Model – generate node names for color channels and eye servos
– enh (dkulp) Detect when Show Directory, FSEQ Directory, or Backup directory are unwritable and re-prompt
– enh (cybercop23) Add pre/post silence to media
– enh (derwin12) Add summary to Check Sequence
– bug (scott) Fix ESPixelStickv4 DMX upload
– bug (derwin12) Fix inconsitent paste behavior with timing tracks selected
– bug (scott) Fix State Dialog buttons being too squished
– bug (keith) Don’t allow saving invalid states in State Dialog
– bug (derwin12) Allow some larger buffers that were restricting some rendering
– bug (derwin12/dkulp) Fix status bar height on HiDPI windows displays
– bug (dkulp) Make sure temp directory is properly cleaned after loading xsqz files
– bug (dkulp) More fixes for Mac xsqz icons
– bug (derwin12) Copy/Paste for AC effects was clearing wrong row
– bug (derwin12) Avoid single dot Ripple outlines
– bug (scott) Fix problems with uploading proxies to FPP
– bug (keith) Fix some issues with “rubber band” selection of effects and timings
– bug (scott) Fix loading some new xmodel formats
– bug (dkulp) Fix upload of virtualdisplaymap if 2d preview uses 0 for center
– bug (cybercop23) Fix some crashes when creating aliases from mappings
– bug (keith) Fix labels in Matrix Dialog
– bug (cybercop23) Fix Moving Head button hightlight color for light mode
– bug (scott) Fix FPP upload for single channel model types
– bug (scott) Fix DDP channel number for Genius Pro DMX output
Status
