Release 2024.16 Released
Status
Not open for further replies.
keithsw1111
Kellyville, NSW
2024.16 September 18, 2024
– enh (derwin12) Add copy model including submodels right click option
– enh (Kyle Grymonprez) Disable prompting for alias saving of newly generated models by default
– enh (Kyle Grymonprez) Node Layout: changing the background colors for dark mode
– enh (dkulp) Make sure we have access to media directories, re-prompt if required
– enh (dkulp) Optimize the init/cleanup of CandleEffect, particularly when applied to large groups
– enh (dkulp) If submodel buffer is vertial, use left/col/right labels
– enh (derwin12) Add RGB support to Image Model
– enh (derwin12/dkulp) Various updates to Time Display if Small Waveform is used
– enh (derwin12) Save Small Waveform preference
– enh (derwin12) Make various abandon messages consistent
– enh (keith) Add F-Prop as a dummy controller
– enh (scott) Visualizer – change export from csv to xlsx and add coloring/formatting
– enh (scott) Visualizer – add gamma
– enh (derwin12) Import Dialog – verify imported sequence framerate and xLights version
– enh (scott) SubModels Dialog: add import of submodels from another layout
– enh (scott) Faces Dialog: add clear selected rows
– enh (scott) States Dialog: add clear, fix validation on drag
– enh (scott) States Dialog: add import from Vendor Dialog downloads
– enh (kylegrymonprez) DDP: Controller config can mandate to not support “Keep Channel Numbers”
– enh (scott) State Effect: Add fading
– enh (keith) Allow setting serial port speed for Renard (Falcon controllers)
– enh (scott) Remember position of State Dialog
– bug (MrPierreB) Fix moving head effect to not reset effects when “None” selected
– bug (scott) Fix Fan Effect: Fan Scale to Buffer giving unexpected results in some cases
– bug (dkulp) Fix: blure/zoom on node level effects
– bug (dkulp) FPP Connect: fix the HDMI connector index for FPP8
– bug (scott) Experience Controllers: fix gamma rounding
– bug (keith) Fix single channel matrix displaying in wrong location
– bug (scott) WLED: Fix WRGB upload
– bug (derwin12) Retain Warp settings when copying
– bug (derwin12) Disable Update button for Base Showfolder
– bug (scott) Hide Individual Start Channels for Cube Model
– bug (scott) Experience Controllers: fix single channel models
– bug (Kyle Grymonprez) Fix crash on old DMX model
Status
