Release 2024.18 Released
Status
Not open for further replies.
keithsw1111
Kellyville, NSW
2024.18 November 14, 2024
– enh (keith) Add ability to “Level” the brightness of color components
– enh (scott) Windows installer works on Arm64
– enh (dkulp) Remove some optimizations that were helpful in the old 32bit builds, not for SSE/Neon (should help Galaxy, plasma, butterfly, etc…
– enh (scott) Add align to closted timing mark for effects
– enh (scott) Add group count support for Genius controllers
– enh (scott) Ability to “invert” channels in DMX mapping
– enh (derwin12) Add last render date to Batch Render dialog
– enh (keith) Optionally disable key acceleration when nudging models on layout panel
– enh (scott) Import layer names from original sequences
– enh (cybercop23) Add sequence number progress indicator to FPP Connect
– enh (cybercop23) Allow models to be “visualized” in either base or show folder
– enh (KyleGrymonprez) Add rondomization functionality to metronome timing track generation
– enh (derwin12) Add submodel support to auto mapping
– bug (dkulp) Fix a potential crash when using host names instead of ip addresses from a base folder
– bug (scott) Windows Upgrade Available notification not working
– bug (derwin12) Don’t trigger a save when clicking on a locked model
– bug (scott) Add some internal checks to prevent overlapping and zero length effects
– bug (dkulp) FPP Connect would not delete some tmp files
– bug (dkulp) MacOS – also delete the bookmarks file when -w passed to reset permissions
– bug (dkulp) MacOS – make sure we have access to the base directory, ask for permission if required
– bug (scott) Fix crash with negative values in audio editor
– bug (MrPierreB) Fix Single Strand Fade type “Head and Tail” for all blending types
– bug (PeteMatthews) Fix color order inheritance issue on ILightThat controllers
– bug (degracode) Fix problems with property grid now being updated when protocol switches to Twinkly
Status
