Release 2024.19 Released
Status
Not open for further replies.
keithsw1111
Kellyville, NSW
2024.19 November 24, 2024
– enh (cybercop23) Re-attempt to resolve host names on CTRL-click or Test if not resolveable when xLights started
– enh (dkulp) If a sequence cannot be saved, report the error to the user
– enh (dkulp) Use better coloring in Dark mode for Import dialog and TwoPoint/PolyPoint model X/Y/Z coords
– enh (cybercop23) Add Skip option to Discovery for controllers that match existing
– enh (cybercop23) Add ability to highlight to/from models in Import dialog to only map that subset
– enh (degracode) Sort controllers in Import from controller (Twinkly) dialog
– bug (degracode) Fix how Custom Model grid is created to create all rows/cols in one call. Much faster.
– bug (cybercop23) Fix performance of AutoMap on Import Dialog
– bug (dkulp) Fix some crashes if ip resolves are still outstanding when switching show directories or similar
– bug (dkulp) Fix some issues trying to determine if a directory is writable
– bug (dkulp) Make sure we can access/write to show directories when selected from Recents menu
– bug (dkulp) Fix crash with Ethernet based controllers that don’t have outputs (FPP Player Only for example)
– bug (dkulp) Fix hang on MacOS when using a lot of Image models
– bug (dkulp) Fix crash on MacOS with “Blur” when using large models in “Single Line” render styles
  • Like
Reactions: AAH
Status
