Release 2025.01 Released
Status
Not open for further replies.
keithsw1111
Kellyville, NSW
2025.01 January 20, 2025
– enh (dkulp) MacOS/Linux – start using ISPC to use SIMD/SSE/AVX/NEON for certain effect renderings
– Butterfly effect ported to ISPC
– Plasma effect ported to ISPC
– Non-spacial color Pinwheel effect ported to ISPC
– Layer Blending ported to ISPC
– enh (dkulp) Butterfly Effect – add styles >5 to Metal rendering
– enh (cybercop23) FPP Connect – split ip and hostname to separate columns, clickable links for each
– enh (scott) FPP Connect – add selection options for subnet, add select all/deselect all for cape
– enh (scott) FPP Connect – more sequence selection options, select based on last batch render
– enh (cybercop23) FPP Connect – add re-discover button to re-run discovery
– enh (cybercop23) FPP Connect – allow option to keep dialog open after uploads complete
– enh (cybercop23) FPP Connect – de-duplicate FPP isntanced based on UUID
– enh (derwin12) Import Mapping Dialog – remove useless timer
– enh (derwin12) On Effect – show gradient in background
– enh (derwin12) Servo Effect – servo background is clearer and more distinquishable
– enh (cybercop23) ESPixelStick v4 – bunch of updates to make upload to ESPixelSticks more reliable
– enh (scott) DMX Remap Dialog – Add Copy/Check/Uncheck to Invert Setting
– enh (derwin12) Effect Settings – filename controls set background to yellow if invalid characters are used
– enh (keith) Controller Properties – provide better warnings/indicators if multiple controllers are configured with same IP
– enh (cybercop23) Check Sequence – move to simple HTML to make report easier to navigate
– enh (derwin12) Layout Tab – add preference to hide/size the Group Crosshair
– enh (derwin12) Layout Tab – Remove invalid controller properies/settings if controller is changed
– enh (derwin12) Layout Tab – add ability to export/import native icicles model
– enh (derwin12) Model Properties – add ability to re-order the aliases
– enh (cybercop23) Model Properties – add ability (and Lua script) to delete all aliases
– bug (cybercop23) Batch Render – don’t list sequences in backup directories
– bug (scott) Fix preview/model import crash if click select sibling on a preview
– bug (dkulp) Fix a crash at startup if controllers in base directories are using hostnames
– bug (dkulp) Fix a crash with single strand effect used in a group with “Per Model” render styles
– bug (dkulp) Fix a potential crash if a controller hostname cannot be resolved
– bug (dkulp) Fix a crash if using Linux in parallels if EGL is required
– bug (dkulp) Fix a crash on Linux if MovingHeadPanel is resized before being placed on screen (startup)
– bug (dkulp) Fix incompatability with Ubuntu 22.04 and Debian 12
– bug (derwin12) Fix getFseqDir Lua command to match conventions, update docs
– bug (cybercop23) Experience Controllers – retain/support Remote/Standalone modes
– bug (dkulp) Butteryfly Effect – clamp HSV->RGB routines to 0..1 for Hue
Status
