Release 2025.02 Released
Status
Not open for further replies.
keithsw1111
Kellyville, NSW
2025.02 January 27, 2024
– enh (cybercop23) Clicking in sequencer should properly highlight the row
– enh (cybercop23) Enable replay button without needing to first hit play
– enh (cybercop23) Add ability to remove model(s) from existing groups from popup menus
– enh (cybercop23) Add popup menu option to add timing track to all views
– enh (cybercop23) Sort and restore controler tab column order
– enh (derwin12) Increase maximum size of group buffers
– enh (cybercop23) Add status message/indicator during Cleanup File Locations
– enh (cybercop23) FPP Connect – show FPP instances that are configured, but could not be found
– enh (cybercop23) Discovery – better job of finding duplicates, matching existing controller, etc…
– enh (dkulp) Pinwheel Effect – “spacial colors” now supported by ispc rendering
– enh (dkulp) Much faster populating of Model List on Layout tab (Mac/Linux)
– enh (dkulp) Add libsecret to Linux builds so wxSecretStore should work (passwords for FPP Connect)
– enh (dkulp) Add setting to disable the effect indicator for deep groups
– enh (cybercop23) Set discovered FPP instances to xLights Only by default
– bug (derwin12) Limit the splitter on the submodel dialog from collapsing all the way
– bug (derwin12) Fix “newSequence” Lua call
– bug (cybercop23) Don’t report if Sketch effect background is missing
– bug (cybercop23) Map meshobjects to proper resources directory during filename fixups
– bug (dkulp) Fix background display issues/fragments when using Single Strand Chase effect
– bug (dkulp) Aliases may not have been properly removed from SubModels
– bug (dkulp) Fix sparkle/brightness/contrast rendering with ispc
– bug (derwin12) Fix problems opening HTML check sequence report in some cases
– bug (dkulp) Don’t pollute the recent sequences list during batch render
– bug (dkulp) Fix some crashes with canvas mode effects with ispc rendering
Status
