cenote
Suburbs of Philadelphia
- Thread starter
- #1
Been working on fiddling around with making a new type of flood. There is a pic over in media of it.
It consist of (3) of each RGB 3w Star Led's. Furture version I would like to have a built in DMX controller within housing.
Up untill about 10 minutes ago, I had severe heat issues with it. Was able to control the current perfect @700mA, but the darn regs and resistors couldn't handle it. Playing with the LM350 regs that are suppose to be good for 3-5 amps. Thanks to AussiePhil, he suggested wiring the regs a little different than standard, and BANG....IT work. Thank you Phil
Have had it turned on now for 15 minutes, blinding the cat, and all chips are only barely warm. Before, within 1 minute, I would either fry the reg, or come close to melting it.
Just need to re-mess with resistors to get the fmA up to 700, only getting about 500 now. Will keep you all posted.
Thanks again Phil, Chuck
[smg id=19][smg id=18] (just added the images Chuck, Phil)
