- Thread starter
- #1
Essentially these are just the RGB sections that will be used in the mega-tree wired up as a 3m (9foot) wide Icicle string.
Nothing fancy
RGB Icicle string
Phil
Nothing fancy
RGB Icicle string
Phil
That was using the 5050 leds, as shown in the video 75mm spacing horizontally and 160mm vertically, it's a neutral light colour wall behind the leds so there is some light reflected from the wall.smartalec said:ps. Now thats something i want for my outside walls, is that using the 5050 leds?
Phil good work with the curtain, looks awesome for just something you quickly slapped together.AussiePhil said:That was using the 5050 leds, as shown in the video 75mm spacing horizontally and 160mm vertically, it's a neutral light colour wall behind the leds so there is some light reflected from the wall.smartalec said:ps. Now thats something i want for my outside walls, is that using the 5050 leds?
I suspect it would look really good with some sort of opaque material in front of it to diffuse the light. There are no covers on those leds yet
phil
It would be interested in knowing the time differences between the time to develop a LSP sequence and a Vixen sequence for the curtain (I already know but others would be curious)smartalec said:Now you have me believing in Vixen again,
Thanks Phil
how long did it take you to do the vixen v's the lsp? care to say?
maybe a little biased there....lightshowpro said:boy those LSP blends sure look nice...
