charleskerr
- May 28, 2011
- Thread starter
- #1
1st, from the data sheet:
The Connection and Driving of Cascading Operation
The transmit the data over long distance by cascading, the WS2801 integrates push-pull output stage with strong driving capability which enables the data and clock can be transmitted up to 6 meters at 2MHz clock frequency.
To prevent the reflection, it is necessary to connect a 50Ω resistor at the data input or output port for impedance match.
Now my questions:
1. On my pixel controller, does this mean I should have a 50 ohm resistor from data to ground and from clock to ground to match up when I connect to the controller strings.
2. If I am building my own strings, on each smart pixel, on my output, I should add a 50 ohm resistor on the clock and data lines to ground.
Have I understood that correctly?
Now my questions:
