3-2-3 T-type splitter wiring for power injection
Discussion in 'Power Supplies' started by cdjazman, Aug 19, 2017.
  1. cdjazman
    cdjazman Full Time Elf
    Apr 24, 2012
    297
    65
    Hello all,
    OK so having brain farts and confusing myself here.
    Just wanting to confirm wiring colors for power injection with Rays 3-2-3 to do straight power injection from power supplies.
    https://www.aliexpress.com/item/3-c...id=dd078ecc-b6cb-4342-b2b0-79336331f227&tpp=1
    Which is the positive?
    I am running power back to my central command and have 2 core coming from power supply to either straight to T-type or via F8 Distro board.
    I have my head around running blue to blue all the way through the setup but my concern is the T-type and should blue be positive from the start or negative?
    Or have i just confused the reader...... :):eek::confused::D
  2. burnt
    burnt Apprentice Elf Generous Elf
    Nov 17, 2014
    72
    35
    [​IMG]
    from rays site.. does this help
  3. Fing
    Fing Full Time Elf
    Dec 31, 2014
    376
    38
    Muswellbrook
    Blue is Negative
    Brown is Positive
    yellow/green data
  4. OP
    OP
    cdjazman
    Apr 24, 2012
    297
    65
    Not really no. This is for 3 core and I am using the T-type with 2 core power injection. Good spot though.
  5. burnt
    Nov 17, 2014
    72
    35
    easy to workout with multi meter.. looking at the pic use the meter to check for circuit from +ve of the 3 pin plug to the 2 way t connector
  6. OP
    OP
    cdjazman
    Apr 24, 2012
    297
    65
    Ok so that raises the following;
    If I follow the Blue --> Blue and work backwards from lights back to power supply then the combination should be fine...?
    I would end up with a combination as such....
    Lights
    T-type splitter (Female end for 2 core)
    Male end -> cable -> Male end
    Female end -> F8 distro (Blue into GND side) -> Female end connected to F8 power
    Female end -> connected to power supply
    And there is my learn something new everyday moment. :):):):):)
  7. lytnin
    lytnin Full Time Elf
    Jul 26, 2010
    102
    12
    North Richmond NSW
    Always test with a multi-meter. I've had a few T-pieces with incorrect wiring, from the same batch.
    Test Test Test
    Boof63 likes this.
