3-2-3 T-type splitter wiring for power injection
cdjazman
Hello all,
OK so having brain farts and confusing myself here.
Just wanting to confirm wiring colors for power injection with Rays 3-2-3 to do straight power injection from power supplies.
https://www.aliexpress.com/item/3-c...id=dd078ecc-b6cb-4342-b2b0-79336331f227&tpp=1
Which is the positive?
I am running power back to my central command and have 2 core coming from power supply to either straight to T-type or via F8 Distro board.
I have my head around running blue to blue all the way through the setup but my concern is the T-type and should blue be positive from the start or negative?
Or have i just confused the reader...... :):eek::confused::D
from rays site.. does this help
Not really no. This is for 3 core and I am using the T-type with 2 core power injection. Good spot though.
easy to workout with multi meter.. looking at the pic use the meter to check for circuit from +ve of the 3 pin plug to the 2 way t connector
Blue is Negative
Brown is Positive
yellow/green data
Ok so that raises the following;
If I follow the Blue --> Blue and work backwards from lights back to power supply then the combination should be fine...?
I would end up with a combination as such....
Lights
T-type splitter (Female end for 2 core)
Male end -> cable -> Male end
Female end -> F8 distro (Blue into GND side) -> Female end connected to F8 power
Female end -> connected to power supply
And there is my learn something new everyday moment. :):):):):)
