300W 5V
cdallen
I'm using a mean well rsp-320-5 power supply which means 60A out. I'm going to fuse the circuit, but do I need to use 60A fuses between psu and component? Do components only draw the amperage they require? does it really even matter from a component point of view?
Really old (now a Grandpa)
Any fuse should be rated to suit the load and the size of wire feeding it.
What are you feeding the power to? Are there multiple devices?
cdallen
honestly at this point just a falcon controller.... and power injection. do i need to add in resistors at some point? there's 3 output terminals on the psu
