3d printing
Shabz_88
Hey guys,
Anyone in australia print and sell the jigs for drilling 1,2 and 3 inch spacing in conduit. Have seen a few in the states but not local.
Shabz_88
I dont have an stl i have only seen a few of the jigs for sale in the states.. i am only new to this hobby and looking to start working on my window surrounds etc..
TRAVISTY
Let's make smoke
This is a new one that looked good
brando
Is there anyone in SE Qld with a 3D printer that would be willing to make me a jig? Does the 3/4” jig off Etsy work for 20mm PVC? Would it not be too tight?
Considered making one myself based off chromatrim but not sure I could be bothered.
Willing to pay if someone can print me one and I can pick up or pay for postage
Adsy
Gaining confidence elf
Radelaide
I don't have a 3D printer but funnily enough i would rather make my own jig :)
brando
More about the time. Only got so much to spare for building everything throughout the year, and if I can save some somewhere, I will.
Kent
Here is one I made up in 5 minutes with some scrap timber laying around and a 25mm spade bit :)
View: https://imgur.com/a/Unf98oA
Rough a guts, but worked a treat.
I'm in Sydney, but can print and post to you if no-one nearby can help out - would need the STL sent to me, though.
BAZMick
I'm in Forest lake, can print something but need design specs or STL/3mf file preferred
AussiePhil
Administrator
Canberra, ACT, Australia
Hey guys,
Are you using a drill press or hand drill?
If you use a drill press then the jig is simple and can loose most of the spacing features as they are not needed.
Not sure i would use a hand drill for this.
If your using a drill press then if needed i can run up a quick jig in fusion360 and publish it here for use
