4 Pin water proof cable connectors
dmoore
Houston, TX, USA
This is detailed photos of the 4-pin waterproof connectors located here:
http://www.aliexpress.com/product-fm/313495011-100pcs-lot-waterproof-led-strip-cable-4pin-used-for-led-strip-RGB-color-wholesalers.html
A "package" of them includes 100 males and 100 female connectors for a total of 100 connections (male+female.) The length is 180mm or 7.1 inches. The ends are completely encased in plstic and they ship with an o-ring end and a screw on connector to keep them from coming apart. The four wires at the end are tinned and are about .5mm in diameter (.019"). The outside cable sheath is 4.45mm/.175". I can't speak for the UV protection long term. Overall they seem nice.
I got a set of these and was wondering whether they would carry the current for 5V * 50 node string, in the end I have ordered a different set which has larger pin and thicker cable
http://www.aliexpress.com/fm-store/701799/210128048-323485322/100-pairs-4-Core-White-Waterproof-Line-15cm-long-each-male-and-female.html
Do you know the gauge of the cable on your set of cables (the white ones)?
I have a set of the white plugs and was more than happy with them. The wire appears to be at least 0.5mm2 but this is not definate.
