Hi all, I have finally been able to do some testing on my code and I am now willing to release it.
I have 2 versions - Functionally the same, just different hardware.
One is for the standard arduino ethernet shield, the other is for the ENC28J60 based module. The difference being that a Uno and Ethernet module will set you back about $20 whereas a Pro mini and ENC28J60 will cost about $6 but requires a bit more work to assemble etc.
This code will allow you to run up to 240 pixels - Possibly more but not a lot. The poor Atmega328 runs out of SRAM.
ENC28J60 Version:
Wiznet/Arduino Ethernet version:
Enjoy!
ENC28J60 Version:
Code:
// E1.31 Receiver and pixel controller
// This code may be freely distributed and used as you see fit for non-profit
// purposes and as long as the original author is credited and it remains open
// source
// The ethernet module is an ENC28J60 based item which are easily available
// for a few $
// Data connections to the module:
// Module -> Arduino
// SI -> 11
// SO -> 12
// SCK -> 13
// CS -> 8
// NB Most of the modules run on 3.3v, not 5v - Use caution! 5V logic/data is fine though.
// Please configure your Lighting product to use Unicast to the IP the device is given from your DHCP server
// Multicast is not currently supported due to bandwidth/processor limitations
// You will need the Ethercard and FastLed Libraries from:
// [url]https://github.com/FastLED/FastLED/releases[/url]
// [url]https://github.com/jcw/ethercard[/url]
// The Atmega328 only has 2k of SRAM. This is a severe limitation to being able to control large
// numbers of smart pixels due to the pixel data needing to be stored in an array as well as
// a reserved buffer for receiving Ethernet packets. This code will allow you to use a maximum of 240 pixels
// as that just about maxes out the SRAM on the Atmega328.
// There is deliberately no serial based reporting from the code to conserve SRAM. There is a **little**
// bit available if you need to add some in for debugging but keep it to an absolute minimum for debugging
// only.
#include <EtherCard.h>
#include "FastLED.h"
// enter desired universe and subnet (sACN first universe is 1)
#define DMX_SUBNET 0
#define DMX_UNIVERSE 1 //**Start** universe
// Set a different MAC address for each...
const byte mymac[] = { 0x74, 0x69, 0x69, 0x2D, 0x30, 0x17 };
// Uncomment if you want to use static IP
// ethernet interface ip address
static byte myip[] = { 10,0,0,10 };
// By sacrificing some of the Ethernet receive buffer, we can allocate more to the LED array
// but this is **technically** slower because 2 packets must be processed for all 240 pixels.
/// DONT CHANGE unless you know the consequences...
#define ETHERNET_BUFFER 540
#define CHANNEL_COUNT 360 //because it divides by 3 nicely
#define NUM_LEDS 240 // can not go higher than this - Runs out of SRAM
#define UNIVERSE_COUNT 2
#define LEDS_PER_UNIVERSE 120
// The pin the data line is connected to for WS2812b
#define DATA_PIN 7
// Define the array of leds
CRGB leds[NUM_LEDS];
byte Ethernet::buffer[ETHERNET_BUFFER]; // tcp/ip send and receive buffer
void setup() {
// Using different LEDs or colour order? Change here...
FastLED.addLeds<WS2812B, DATA_PIN, GRB>(leds, NUM_LEDS);
// No checks in here to ensure Ethernet initiated properly.
// Make sure Ethernet cable is connected and there is DHCP on the network ....
ether.begin(sizeof(Ethernet::buffer), mymac);
// DHCP
//ether.dhcpSetup();
//Static IP
ether.staticSetup(myip);
// Register listener
ether.udpServerListenOnPort(&sACNPacket, 5568);
//Once the Ethernet is initialised, run a test on the LEDs
initTest();
void loop() {
//Process packets
ether.packetLoop(ether.packetReceive());
static void sACNPacket(word port, byte ip[4], const char *data, word len) {
//Make sure the packet is an E1.31 packet
int count = checkACNHeaders(data, len);
if (count){
// It is so process the data to the LEDS
sacnDMXReceived(data, count);
void sacnDMXReceived(const char* pbuff, int count) {
if (count > CHANNEL_COUNT) count = CHANNEL_COUNT;
byte b = pbuff[113]; //DMX Subnet
if ( b == DMX_SUBNET) {
b = pbuff[114]; //DMX Universe
if ( b >= DMX_UNIVERSE && b <= DMX_UNIVERSE + UNIVERSE_COUNT ) {
if ( pbuff[125] == 0 ) { //start code must be 0
int ledNumber = (b - DMX_UNIVERSE) * LEDS_PER_UNIVERSE;
// sACN packets come in seperate RGB but we have to set each led's RGB value together
// this 'reads ahead' for all 3 colours before moving to the next led.
//Serial.println("*");
for (int i = 126;i < 126+count;i = i + 3){
byte charValueR = pbuff[i];
byte charValueG = pbuff[i+1];
byte charValueB = pbuff[i+2];
leds[ledNumber].setRGB(charValueR,charValueG,charValueB);
ledNumber++;
FastLED.show(); //Do it!
int checkACNHeaders(const char* messagein, int messagelength) {
if ( messagein[1] == 0x10 && messagein[4] == 0x41 && messagein[12] == 0x37) {
int addresscount = (byte) messagein[123] * 256 + (byte) messagein[124]; // number of values plus start code
return addresscount -1; //Return how many values are in the packet.
return 0;
void initTest() //runs at board boot to make sure pixels are working
LEDS.showColor(CRGB(255, 0, 0)); //turn all pixels on red
delay(1000);
LEDS.showColor(CRGB(0, 255, 0)); //turn all pixels on green
delay(1000);
LEDS.showColor(CRGB(0, 0, 255)); //turn all pixels on blue
delay(1000);
LEDS.showColor(CRGB(0, 0, 0)); //turn all pixels off
Code:
// source
#include <SPI.h>
#include <Ethernet.h>
#include <EthernetUdp.h>
byte mac[] = { 0x74, 0x69, 0x69, 0x2D, 0x30, 0x15 };
IPAddress ip(10, 0, 0, 10); //IP address of ethernet shield
EthernetUDP Udp;
#define DATA_PIN 7
unsigned char packetBuffer[ETHERNET_BUFFER];
void setup() {
Ethernet.begin(mac,ip);
Udp.begin(5568);
initTest();
void loop() {
//Process packets
int packetSize = Udp.parsePacket(); //Read UDP packet count
if(packetSize){
Udp.read(packetBuffer,ETHERNET_BUFFER); //read UDP packet
int count = checkACNHeaders(packetBuffer, packetSize);
if (count) {
sacnDMXReceived(packetBuffer, count); //process data function
void sacnDMXReceived(unsigned char* pbuff, int count) {
ledNumber++;
int checkACNHeaders(unsigned char* messagein, int messagelength) {
return 0;
delay(1000);
delay(1000);
delay(1000);
Enjoy!
