Jago
I have been working on a Arduino base strobe project.
Took ideas I had plus ideas I had seen here and combined into this project.
Most the coding is finished, The DMX is not fully tested.
[attachimg=1]
Features
All setting are stored in EEPROM, so any settings set at LCD can be saved. DMX settings are not saved between power cycles.
[attachimg=1]
Features
- Nodes: This sets the number of nodes(pixels) in the string. This setting requires a reset and can only be set at LCD
- Address: This is the DMX start address. Can only be set via LCD.
- Chip: This select what chipset the lights have. This setting requires a reset and can only be set at LCD.
- Mode: Disabled, DMX, Manual. This setting can be only be set via LCD and is realtime.
- Speed: This can be set via the LCD or via DMX all updates happen in realtime. Speed is the delay between strobes values can range from 0-3000ms
- Fill: This is how many lights are on at onces. This vale can be set via LCD and DMX and ranges from 1 to Node Count. This value is realtime.
- Flash: Controls how long the strobes stay on for. Can be set via LCD and DMX. Has a range of 1-100 and and is realtime.
