Another Arduino Strobe Project
Jago
Townsville
I have been working on a Arduino base strobe project.
Took ideas I had plus ideas I had seen here and combined into this project.
Most the coding is finished, The DMX is not fully tested.
[attachimg=1]
Features
  • Nodes: This sets the number of nodes(pixels) in the string. This setting requires a reset and can only be set at LCD
  • Address: This is the DMX start address. Can only be set via LCD.
  • Chip: This select what chipset the lights have. This setting requires a reset and can only be set at LCD.
  • Mode: Disabled, DMX, Manual. This setting can be only be set via LCD and is realtime.
  • Speed: This can be set via the LCD or via DMX all updates happen in realtime. Speed is the delay between strobes values can range from 0-3000ms
  • Fill: This is how many lights are on at onces. This vale can be set via LCD and DMX and ranges from 1 to Node Count. This value is realtime.
  • Flash: Controls how long the strobes stay on for. Can be set via LCD and DMX. Has a range of 1-100 and and is realtime.
All setting are stored in EEPROM, so any settings set at LCD can be saved. DMX settings are not saved between power cycles.
Thx for sharing your project, have a couple of arduino boards and displays sitting idle, looking forward to having a play when you finish coding.
Just doing the last of the testing now. Was waiting on the MAX485 to arrive.
Here is the shield I built.
Been tweaking the DMX code a bit to get better value mappings.
Don't have a full string of strobes to show it with (got a string from ray wu coming) I can make a video then.
Note: The jumper is not needed as a rule. I have it there so I can update the program easier as the MAX485 uses a serial interface and thus interferes with the usb programmer
Here is first version of the code.
There is no warranty on this code. I have tested it best I could and it works on my tests.
  • Strobes.zip
I can see an excess of heat halfway along the bottom edge of that shield. Need a tougher shield :)
