Aquatran Transformer vs HPM vs ?? 12V
damona
[SIZE=small]People have any thoughts on these. After a power supply with all the Australian Ticks.[/SIZE]
[SIZE=small]http://www.rockaroundtheblock.com.au/garden-lighting/transformersncable/12-volt-ac-transformers.html[/SIZE][SIZE=small] https://www.springers.com.au/images/contentpics/pdf/aquatran%20aqo%20product%20guide-email.pdf [/SIZE]
[SIZE=small]vs[/SIZE]
[SIZE=small]http://www.bunnings.com.au/hpm-12v-400w-garden-transformer-_p7070686[/SIZE][SIZE=small] e.g. can not touch the 240V[/SIZE]
Can they be connect together to get more AMPS/Watts.
[SIZE=small]Where I am coming from is being able to use a Power Supply that has a 240v *plug* one end and a 12V the other end and has all Australian Ticks... e.g. not from overseas. [/SIZE]
[SIZE=small]Any one have some thoughts...[/SIZE]
The Meanwell HLG outdoor rated series of power supplies comes with all the ticks and an Australian plugged 240v cable, all you do is connect up the 12vdc side, I use these as they have the correct Australia certification and are top quality and reliable, I've not had one fail yet, but they also do come at a price.
I may have a couple of 240 watters left here if you need
