- Jul 10, 2024
I created a set of 8 arches using this 2" tubing and they came out great. Been using them for 4 years now. My next project is to use that same tubing but sized so is only enough for the LED strip and maybe power injection wires. What I'm attempting to do is the attach the tubing to the bottom of the wooden fence that surrounds my back yard to provide some soft lighting of my entire yard. Here are the specs and random thoughts on the build. Would love any guidance or recommendations.
			- Length of Fence: 288 feet
- Is this 1" tubing large enough that it will have minimal hot spots?
- Is 7/8" internal tubing diameter big enough for strips and power injection wire if needed.
- 12v versus 24v led strips?
- 4-wire strips with backup data to avoid maintenance if just a few nodes go out?
- LED strip spacing? If closer-spaced, will it help with hot spot mitigation?
- Will I drive myself nuts trying to straighten 288 feet of tubing that comes in a circular roll? Will be using these pipe straps to attach to fence.
- For power injection, should I consider running a power supply with higher voltage and use a converter at point of injection since it may be far away? 24v stepped down to 12v.
