L
LightEnthusiast_LOR
Guest
- Thread starter
- #1
Originally posted on February 7, 2009
I decided I would start experimenting with the power boards, I bought some of the Bunnings red insulated quick connects. I have cut the plug and stripped back the white plastic casing for the wires and then stripped 1cm from all the wires. Is this a good amount to take off ?
I'm starting with the active wire, I read that I should twist it around so the wires are in a spiral. When I put the wire in the connector it seems that 1cm is good the plastic starts on the wire just after the part where it is crimped
I'm talking about the connectors for the PC boards.
There is the slightest bit of wire that goes past the bit that's crimped is this ok or do I want more wire or less? Does that matter or do i just want to make sure that there is a good strong connection to the connector and the wire shouldn't come out of the insulated cover for the connector?
LE
LE
