Daniel1973
- Thread starter
- #16
CaptainMurdoch said:From the Troubleshooting Commands page under the helps I you should be able to see if your BBB received an IP address from the DHCP server on your router. At the top of the page there is an "ifconfig" section which lists the IP info for the wired and wireless interfaces. Does it show an IP for eth0?
If it does show an IP for eth0 then look a bit further down the page and you will see a section where it tried to ping GitHub which is where the source is stored at. If you are getting a github error on the other page then there will probably be an error on the troubleshooting page. What error is there, that should tell us why it can't get to the internet.
Captain
This is what is on Command page.
eth0
Link encap:Ethernet HWaddr 78:a5:04:f5:36:e6
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:744 errors:0 dropped:0 overruns:0 frame:0
TX packets:13 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:71615 (69.9 KiB) TX bytes:4446 (4.3 KiB)
Interrupt:40
and Further down
Internet Access: ping -c 1 github.com
ping: unknown host github.com
Daniel
