plasmadrive
Just for yucks the other day I tried my Styrofoam cutter (heated wire) and it worked. I bit slow but it was only a 10W cutter. Assuming I what I have is not PVC and I can safely melt it, I was thinking about perhaps making a hotter wire under tension to cut the stuff.
Another idea was to make templates from wood and use a router with a small straight double fluted bit at high speed... Same as a CNC but by hand.
Not sure which would work better.. but something to play with over the spring time
