Roosta
- Dec 8, 2015
Each set of 100 pixels would draw 5A - 6A on full white, so no surprise that 2 sets of 100 are blowing a 5A fuse.
Also, do you really have the V+ line connected at the top at each direction change? (you should not)
David could you please give a reason why not to have the + connected in the direction change.
I thought it was ok to connect for the direction change for each run from each PSU supply
Not ok to link between the PSU supplies as per this schematic posted by Roosta
I am intrigued by both your comments, and would like to understand why not linking at the top or bottom (which ever is the case) is not ok? I am guessing this is specific to those using small fused distro boards..
By linking both, in my mind, supplied by a single large fuse, while allowing the oppurtunity for a large surge to flow through on a short, just shares the load and reduces the overal resistance of the voltage circuit, thus reducing voltage drop by a little, and offering mutliple paths for the power to get to the LED in case of a solder joint breakdown.
Maybe I have the wrong take on this..
