Cable End Termination - What do you use?
Gooliez
Spreyton, Tasmania
For the most part I put a xConnect pigtail on the end of the string so I can daisy chain the prop to something else. In emergencies and in a rush I have used heat shrink tubing with glue to seal the end off. While I like the thought of liquid electrical tape just not for outside where it can peel and flake and still expose the end of the string to weather and corrosion.
put on an xconnect for chaining or PI, and then use xconnect end caps.
ofcourse i should do that ( for props anyway) why didnt i think of that. lol
What should I used for permanent fixture guttering runs where there will never be any more added?
If I don't plan to connect anything to the end of a prop, i'll crop the wires and put on a bit of glued heat-shrink tubing, heat that up and squeeze the end to seal it together, I repeat this for each wire.
OMG, look at how many lights you have 🤣🤣, something to aspire to.
judging from that, you know what you are doing... guess i'll be doing that. lol
I mean it's fine for 5-24v but anything more I would be using something more robust, I would not for example be doing that for anything 230v mains powered. I am an electrician so can confidently say, don't just leave live ends hanging out!
So everyone's cut their cable at some point.
I'm at the stage where I've got a custom prop and have 100 Pixel Strands, but only need 82.
What are people closing the end with?
I saw a video that uses "Liquid Electrical tape" after googling, Amazon has some. but before i go ordering, what are your thoughts, or would you recommend something else.
https://www.amazon.com.au/gp/product/B0G1MG2R3P/ref=ox_sc_act_title_2?smid=A3L8UDJVUBCW6I&psc=1
Liquid electrical tape works a treat. Been using it for years without any problems. Can also get from Jaycar.
You don't plan to add anything to the end of the prop... NOW... but may do in the future. Future Gooliez will thank you later ;)
Alternatively I just add some heatshrink and fold it over to form a weatherproof(ish) seal that is easy to undo and add more pixels or connector in the future.
