Am only on the other side of country (via I-90), not world. Last one I mailed was well under $100.
I think the LoR modulates the 16 hot wires, and the neutral and ground are always connected. If you use a relay to intercept the neutral you only need 1 relay, rather than 15 to intercept all the other hot wires.
Some LoR can do 30A and have 2 power plugs. Those you would do 2 relays for neutral.
So hot1 -> comnect to both set 1 prop 1 and set 2 prop 1... and so on through 15
Netural->relay->set 1 prop 1-15 and opposite to set 2 prop 1-15
Ground to everything.
