cannot see house preview in layout tab
Kaite Clocks
Royal Park
is anyone having problem seeing house preview in layout tab in version .51.
my screen is all black where house should be.
when you click on model, blue node points highlite where the model , but i cannot see them.
hope some can help
Ancient version ... pls check your video drivers are up to date.
You can also try using th settings menu to lower the open gl version to 1 or 2 and see if that helps.
2017.6
You shouldnt need to use opengl 2 unless you are running an ancient machine I suggest you update your video drivers and go back to atomatic.
