cenote
Suburbs of Philadelphia
- Thread starter
- #1
Have a question for technical people on here. I was playing with the CL25N3's and ended up blowing up a set of expensive 5-chip 100mA LED's. Wondering what I did wrong and why smoke?
Here is the CC Chip specs: http://www.supertex.com/pdf/datasheets/CL25.pdf
I had 24v on Va
Had (4) CL's wired parallel
Had (3) 3.2v 100mA 5-chip LEds in series after CL
Had a good amp meter inline before CL
When I plugged in, I blew the 200mA safety fuse on meter
Of coarse I had to bypass the fuse (first mistake) and turn hooked it up to the 10amp setting...here is when it went bad....
Plugged in, and pufff went the LED's, cat ran out of room cause of odor
Any suggestion, and don't say wait for the Nudies to come....looking to construct some to withstand some heat.
I had 24v on Va
