Dig Octa (fault ?)
fugley
wondering if someone can point me in the right direction here
i noticed one prob not working which happens to be the only prob on this port
on checking the controller i noticed a red light beside the fuse (not a problem ill change the fuse as it must be blown)
But still know luck.
Red light still on and know working prob
thinking there maybe a short in the prob or wiring to that prob i plugged in a known working string of lights which return the same red light on the fuse and know working lights
best i can see atm know fuses were ever blown
which makes me start to wounder if there's a fault with the powerboard
QuinLED-Dig-Octa Brainboard-32-8L with a QuinLED-Dig-Octa Power-7 which is showing the red light
fugley
i used the same rated fuses and to be fair non appear to be blown even tho i did change the fuse for a second time when using a know working string of lights just to be sure but got back the same result
fugley
Thanks ... checking this morning with a multimeter revealed the eyesight isnt what it once was lol
now to see why a cable after two weeks of working fine developed a short
cheers
