DMX DIP Switch Setting Chart
Guys, this chart may help some of those that have DMX equipment that uses DIP switches to set the DMX address as it gives the dip switch settings for each channel in a DMX universe. I know ill find it helpful
DMX dip switch chart original from http://www.look4ideas.com/application_notes.html
  • DMX DIP Switch Chart.pdf
Nice reference Eddy. Perfect to print and use when you're away from your PC.
Would a web / small program version be useful as well ?
Anything helps when it comes to setting DIP switches, I know last year i spent some time working out the dip switch settings for the correct address on a fixture i used, just wish i had good reference at the time.
The thing that needs to be tested is that the chinese DMX lighting has the same settings
Yeah, some equipment is actually address 1 when all switches are off. I'll see what's around in the way of a javascript DIP switch calculator.
thought there would be one on the AVD site. but couldn't find it there
Thanks for that one too RADLX that saved me going to the computer all the time
There is also a bunch of them for Android, just search for DMX on market and install, most of them are free.
I can't remember where I got this, but it seems to work.
  • bits.zip
And if you are NOT a fruitboi ;)
https://market.android.com/details?id=com.cocoa_mobile.dmxdip&feature=search_result#?t=W251bGwsMSwxLDEsImNvbS5jb2NvYV9tb2JpbGUuZG14ZGlwIl0.
